BOCSH SRS5612/08 drain pump
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BOCSH SRS5612/08 drain pump
  • #59212
    tkaplanis
    my dishwasher doesnt pupm out the water at the end of cycle. I can hear the pupm trying to work for about a minute then it stops. Ive checked the outlet pipe which is clear, as are all the filters. My next step i need to access the pupm but i cant see how to do so ….i know where the pump is but i cant access it, bocsh they wont give me the service manual. Please Help thank you in Advance
    #337370
    Re: BOCSH SRS5612/08 drain pump
    I can’t blame Bosch as it’s a real swine of a job best left to the experts. Tight space, hard to access without a lot of surgery. I would advise contacting a local independant repairer to sort it for you. Check using THIS LINK😀
    #337371
    CJAPeterborough
    you can some idea of the layout of the machine from the Bosch site.
    https://www.bosch-eshop.com/eshop/bosch … SHOPTYPE=A
    you need to remove the bottom front plastic support and kick plate.
    Then remove the metal shield behind -you will then see the pump
    on the left side of the sump housing.
    It is bayonet mounted -its keyhole surgery but dooable…….
    Hope this helps.
    Plug out if you are going in…..
    #337372
    tkaplanis
    thank you for you advice Martin…but im trying to save money its to expencive !!
    #337373
    tkaplanis
    thank you CJAPeterborough ill try to do it and i let you know …..your advice is very helpfull so far!!!!
