bocuse 2040 oven problems
  • #25110
    chirotoon1217
    i purchased the bocuse i wrote about earlier. thanks for your help. after using the cooker for 3 or so months the ovens have stopped working. first the left then the right. they seemed to work for a while when set on the lower temp but now nothing. do i need the oven controllers or is it something else?
    thanks
    alton
    #204526
    Dave_Conway
    Re: bocuse 2040 oven problems
    Possibly the selector switches have burnt out, each oven has it’s own.
    It may also be a thermostat problem, the left oven one is now obsolete.
    This requires a visual and/or electrical inspection, the repairs@ link below should provide someone for you to do this 🙂
    If you do decide to have a look yourself, please disconnect the cooker from the power supply completely :zap:
    #204527
    chirotoon1217
    hi dave,
    thank you for your reply.
    the link seems to only be for uk repairs. i am in the us. is there a way to check this out on my own? you say the thermostat is obsolete do they have a replacement for that or do i just have to junk this stove?
    thank you for your time
    alton
    #204528
    Dave_Conway
    There is probably a generic thermostat that should fit if that is what the problem is.
    The selector switches are still available from Rossieres 🙂
    Only a visual and/or electrical test of each will narrow it down.
