boot rubber
  • #56505
    ELTEL
    Hi as any one changed a boot rubber on a BEKO WMA 767S
    washer
    is it a simple job or a strip down
    thanks
    Eltel
    #327779
    Re: boot rubber
    take the front off the machine same as hotpoints bosch etc
    Seamy
    Re: boot rubber
    Through the door, 5 min job, fairys liquid on seal when fitting & on pinkies when putting on inner spring !
    #327781
    ELTEL
    Re: boot rubber
    Are we talking the same machine the boot rubber is fitted and then it looks like a cast iron weight is fitted on top no way can get boot rubber off of on
    Eltel
    The model is a beko WMA 767S
    #327782
    Jazzmeister
    Re: boot rubber
    to make it easy…remove the front of the appliance then use a torx bit to undo the weight securing bolts….remove the weight then hey presto is an east fit. This will take you in total about 20 mins!
    hope this helps..Jazz!
    #327783
    Re: boot rubber
    I’ll swap you five Beko seals for one Smeg made Whirlpool integrated washer/dryer I did for the first time today, a real arse of a job. 😥
    ELTEL
    Re: boot rubber
    Hi Jazzmeister
    Thanks did the job fine took a bit longer only a small kitchen no space to work but job done thanks again
    Eltel
    #327785
    Jonah
    Re: boot rubber
    Even worse than the SMEG is the Siltal made CDA CI592 washer dryer, impossible without removing the tub, I’ve tried before for hours on them and couldn’t change one, have the scars to prove it :eeek:
