Bosch
  • #55990
    waters
    Bosch wfd2072.Looking for a pattern heater for this.I can only find genuine,the Bosch none genuine look the same so is there a reason why they wouldnt fit
    #325841
    Re: Bosch
    As long as its a 1900w, of the same dimensions, has the same rubber grommet and you swap over the original NTC, it should be OK. Failing that only the genuine (488731) will fit. HTH? 😀
    #325842
    waters
    Re: Bosch
    Thanks,look like they only do 2000w or 2050w
