Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch 1200 Classixx
- This topic has 9 replies, 5 voices, and was last updated 18 years, 9 months ago by
jimmyp.
July 12, 2007 at 11:42 am #28940
jimmyp
ParticipantHi guys, got a bosch classixx 1200 washing machine which I have owned for a couple of years, machine gets worked fairly hard two three washes per day. Wife’s been happy with it until it started to continually take in water, seems to over fill slightly but go’s through its cycle until spin cycle then it stops. We can make it spin the cloths by selecting the spin cycle. This machine has a led display that normally counts down to zero when washing, I’ve noticed this has been erratic and is changing up and down. Is this the programmer at fault or could some other fault cause these symptoms, I’ve cleaned out the water pump filter, which was reasonably clean. 😯
July 12, 2007 at 12:37 pm #220762Martin
ParticipantRe: Bosch 1200 Classixx
Please give us the full model number shown on the inside of the door? 😉
July 13, 2007 at 6:48 pm #220763jimmyp
ParticipantOk martin the number is
wr02466gb/07 fd8411617118
hope this helps,
the machine seems to be doing the same thing on all types of washes and settings 🙁July 13, 2007 at 7:12 pm #220764Penguin45
WFO2466GB/07, I think you’ll find.
I suspect that you have a problem with the water level control system. This works by the displacement of air from a collecting bell attached to the bottom hose of the machine. The air is forced up a skinny hose, into a diaphragm switch at the top. The collecting bell can become blocked by sludge, the air hose can chafe through, or the switch can become faulty.
Switch is p/no 172693 if that proves to be the fault; spares@ukwhitegoods.co.uk will get you promptly.
Stay safe, power off at all times.
Penguin45.July 19, 2007 at 9:33 pm #220765jimmyp
ParticipantThanks for the info, I ve checked the hose and bell, all looks to be in good condition, switch seems to click when pressure put through the hose. hose is clear not blocked, should i try a new switch or is there a way of testing it. i have a meter. water continues to enter machine write through the cycle.seems to be rinsing constantly. Any idea’s appreciated.
July 19, 2007 at 10:10 pm #220766gegsy
With the power off, take the feed wires off each valve in turn, then set on spin and see if you still get the same symptoms.Greg
July 22, 2007 at 2:35 pm #220767bulldog
jimmyp wrote:Hi guys, got a bosch classixx 1200 washing machine which I have owned for a couple of years, machine gets worked fairly hard two three washes per day. Wife’s been happy with it until it started to continually take in water, seems to over fill slightly but go’s through its cycle until spin cycle then it stops. We can make it spin the cloths by selecting the spin cycle. This machine has a led display that normally counts down to zero when washing, I’ve noticed this has been erratic and is changing up and down. Is this the programmer at fault or could some other fault cause these symptoms, I’ve cleaned out the water pump filter, which was reasonably clean. 😯
CHANGE THE MOTOR BRUSHES 😆
July 22, 2007 at 2:38 pm #220768bulldog
bulldog wrote:
jimmyp wrote:
Hi guys, got a bosch classixx 1200 washing machine which I have owned for a couple of years, machine gets worked fairly hard two three washes per day. Wife’s been happy with it until it started to continually take in water, seems to over fill slightly but go’s through its cycle until spin cycle then it stops. We can make it spin the cloths by selecting the spin cycle. This machine has a led display that normally counts down to zero when washing, I’ve noticed this has been erratic and is changing up and down. Is this the programmer at fault or could some other fault cause these symptoms, I’ve cleaned out the water pump filter, which was reasonably clean. 😯CHANGE THE MOTOR BRUSHES 😆
sorry did nt read the whole fault also clean out the pressure system
July 24, 2007 at 6:28 am #220769jimmyp
Participanthi gegsy
when you say valves do you mean the wires on the pressure switch, or the water intake valves. when the machine is set to spin it emptys the water and spins normaly. any other setting it constantly takes water in and pumps it out, never floods though. :rolls:July 24, 2007 at 7:21 am #220770gegsy
It certainly sounds morel like a pressure system fault as suggested previously tbh 😕
