Bosch 1200 Classixx Washing machine won’t stop spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch 1200 Classixx Washing machine won’t stop spinning
  • #58466
    wiltshirewasher
    Hi All
    I have a Bosch 1200 Classixx washing machine, model no WF02466GB.
    When it reaches the end of its cycle it gets stuck on spin and keeps on spinning until you turn it off. The timer display remains at “1” (meaning 1 minute remaining).
    I’ve recently replaced the brushes on the motor and the pump. Any ideas on what might be causing this problem?
    #334624
    Herecomesthesun
    Re: Bosch 1200 Classixx Washing machine won’t stop spinning
    Hello
    Did you manage to sort out this problem as I am experiencing the same?
    #334625
    Some of the guys that work on Bosch washing machines may be able to answer a lot better than I can as I don’t know them at all well.
    Are there any error lights coming up on it?
    odom
    It’ll most likely be an open circuit or down to earth heating element. Unplug machine and check with a meter to be sure.
