Your drum spider support is cracked. The spider ( an aluminium alloy ) has 3 arms and a hub with the bearing shaft, 1 or more arms has rotted and cracked. The spider comes with a new drum as one unit but to be sure I would need the ENr model number as read off your label which is on the inner door frome near or at the top of the door. Not exactly cheap to get done and involved. Most folks would call it a day and buy a new machine and I would advise you to do just that.
