Bosch
  • #31328
    clocknut
    Hi our WFT 2800 goes through the wash cycle fine but stops at the spin cycle any advice would be much apreciated 😉
    #230679
    gegsy
    Re: Bosch
    Does it do the rinses? and are the clothes when in the “fault”, still in water?
    If so, it may be worth checking that the Rinse Hold button hasn’t been activated.
    IIRC on these, the button springs back flush even when activated thus indicating that it hasn’t been pressed 😉
    clocknut
    Re: Bosch
    Hi Greg thanks for the reply my wife has tried to go through a washing cycle I got the info wrong :rolls: it stays in the washing cycle and you can hear a relay clicking but returns to the washing cycle 😕
    #230681
    gegsy
    Re: Bosch
    With the appliance unplugged, its worth checking the heater with a multimeter for approx 20-30 ohms.
    clocknut
    Re: Bosch
    Hi Greg it measures 24.4 ohms so looks to be fine ❓
    #230683
    gegsy
    Re: Bosch
    I take it that its turning?? If not you will need to remove motor and split it in half to gain access to brushes. If they are are worn and you feel up to the job, they can be purchased from here http://shop.ukwhitegoods.co.uk/product_ … cts_id=422
    If not then feel free to use the link below to find an engineer in your area
    Unplug appliance first of course :plug:
    #230684
    clocknut
    Re: Bosch
    The motor is turning Greg thanks again, are we heading for a module fault ❓
    #230685
    gegsy
    Re: Bosch
    Does it actually heat the water (touch the door glass midway through wash)?
    clocknut
    Re: Bosch
    I switched the machine back on Greg and it went straight to the rinse part of the cycle then just froze on the spin section! light on no motor function!
    The heater is working fine Greg 😕
    John.
    #230687
    gegsy
    Re: Bosch
    Definately on spin? and has it drained all the water out?
    clocknut
    Re: Bosch
    Update Greg as it stuck there on spin so we started a new wash where it stopped in the main wash 4 double clicks of a relay with a slight buzz between open and close then back into the wash again to repeat the 4 clicks etc stuck!
    #230689
    gegsy
    Re: Bosch
    Does possibly sound like a power module fault IMO, cannot be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} without being there sorry. Unless some of the other engineers on here have any more ideas 🙂
    clocknut
    Re: Bosch
    Thanks Greg it gets stuck for sure at the wash cycle if you do a mains reset it starts washing again so the module is not resetting it looks like it may be a module problem ❓ If I switch the mains off it should on the panel as well as the socket it should when both switched on be dead till the start switch is activated but it is remembering where it was ❗
    Thanks,
    John.
    Tried a total off again this time it went to normal no light on untill you do a function ❗ ❗ ❗ sticks in wash but no spin if you select it pumps the water out ok before trying to spin.
    #230691
    clocknut
    Re: Bosch
    Hi Greg problem solved I took the module out and there was a dry joint on one relay contact on the print which had been arcing I cleaned it up hard wired it reffited it and it is fine 😀 thanks for your help.
    John.
    #230692
    gegsy
    Re: Bosch
    Glad you sorted and no part needed 😀
