Bosch 7702 Fridge Freezer with faulty fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch 7702 Fridge Freezer with faulty fridge
  • #8449
    Tarzey
    I have an eight-year-old Bosch FD7702 fridge-freezer KGU3201/GB in which the fridge appears to have failed.
    The first point to note is that the freezer part appears to be working normally.
    The fridge, however, usually shows a temperature of 11 or 12 degrees, even when the desired temperature is screwed down to 2. It is in this condition most of the time, but once or twice a day it does cool down to the required 2 degrees. I have the impression (possible quite wrongly) that this has some association with the freezer compressor coming on to work.
    I have asked Bosch’s service department (as they are laughingly called) for help, but all they say is that they can send an engineer, who will charge me £60 for the privilege of having him park his van on my drive – and the cost of any repair is on top of that.
    Can anyone offer any advice about this fault, and the cost of a remedy? Or should I just put the money towards a decent Liebherr?
    #128704
    gegsy
    Re: Bosch 7702 Fridge Freezer with faulty fridge
    The fault could be possibly two things
    1/ Faulty main PCB
    2/ Faulty divertor valve
    I would certainly get an engineer to check before jumping the gun.
    part 1 is app £90 GBP
    part 2 is app £60 GBP
    Regards
    BSH-MAN
    The fault is almost certainly the evaporator sensor for the fridge. As the sensor is not readily accessible, you cannot just change it. 🙁 There is a repair solution! A replacement module (263782 IIRC) does away with the sensor by using time to control the fridge evaporator defrost instead of sensor info.
    That will be £59.50 please. :mrgreen:
    #128706
    gegsy
    What about the overheated diodes on main pcb BSH man 😉
    #128707
    BSH-MAN
    gegsy wrote:What about the overheated diodes on main pcb BSH man 😉
    :mrgreen:
    The hot diodes on the top module are in fact a “feature” The purpose is to warm plates sat on top of the appliance! 😉
    #128708
    gegsy
    BSH-MAN wrote:
    :mrgreen:
    Ah I see, they think of everything the Germans. 😆
    #128709
    Dave_Conway
    :rotl:
    Nice one bsh-man
