bosch
  • #32129
    fasetester
    hi guys have to look at bosch intergrated dishwasher. model sl15jib the problum is the pump keeps running but as i was talking to the woman she said she tryed it and it started to work. any pointers what could be wrong if it was flooded it would not start to work with out drying out the antiflood or could it be a blockage . of the transfair pipe going to the sump can the transfair pipe be cleaned from the sump. thanks fasetester 🙂
    #233719
    Re: bosch
    fase,
    First off I have to say you know the score with regard to the base flooding and all that goes with it and what to do when issues like that come up. 😉
    Secondly, again you have the incorrect model number and if the customer gave you the info,then I’m not surprised it’s wrong? :rolls:
    Can I therefore seriously suggest you at least first of all go and check it out then if you have a problem? Let us know and I for one will pull all the stops to help you out….. 🙂
    GO FASE….YOU CAN DO IT…! 😀
    #233720
    fasetester
    Re: bosch
    thanks martin for the reply would any one know from that number what the mod is thanks fasetester 🙂
    #233721
    Re: bosch
    fasetester wrote:hi guys have to look at bosch intergrated dishwasher. model sl15jib
    That’s not a Bosch model number Fase, some other make maybe? But not a Bosch. 😕
