bosch 8206
  • #13923
    delta01
    fills heats main pump runs but does not move on or pump out ,tried replacing pump coil , still same, can ayone help please ?
    thanks to all for suggestions
    found problem it was a sneakly concealed fuse in the form of a small circuit board it just clips into a housing in the main plastic base, the original pump had discoloured coils so it probably blew the fuse
    #157183
    Re: bosch 8206
    Need to work a bit harder on that model number. that looks more like a date code “FD” number than a model. is there voltage present at the pump?
    #157184
    Re: bosch 8206
    As you don’t say you’ve removed it, is the pump itself OK/not blocked/not seized?
    Mike.
