Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Bosch Advantixx 8 – E09
- This topic has 13 replies, 2 voices, and was last updated 6 years, 9 months ago by
jtheobald.
June 20, 2019 at 2:01 pm #96029
jtheobald
ParticipantHi,
I have a Bosch Advantixx 8 which has developed an E09 error code. Starts but cuts out after a couple of minutes.
Removed front bottom covers, and back and cleaned out crud but nothing seems to resolve issue. Also run the machine without covers on to ensure that it’s not being suffocated.Anything else I can look at? Advice more than welcome as it will stop the ear-ache 🙂
John.
June 20, 2019 at 2:23 pm #462099electrofix
Moderatorwell before anyone can comment we would need the Enr ans FD numbers so we know which machine it is
have you looked in the owners manual for clues ?
June 20, 2019 at 2:36 pm #462100jtheobald
Participantelectrofix wrote:well before anyone can comment we would need the Enr ans FD numbers so we know which machine it is
Hi Dave, fair comment.
WTV74306UK/11 FD 9002 200135
Manual only talks about cleaning out machine.
John.
June 20, 2019 at 8:23 pm #462101electrofix
Moderatorsome of the post I found online seem to suggest the overheat stat on the element so I suggest you test this first
this stat is mounted on the element at the rear and you will need a multimeter to test it
June 23, 2019 at 8:09 am #462102jtheobald
ParticipantHi Dave, Which one is the overheat stat? I have two sensors on top of heater element; one with a red dot on it. And one sensor which is approx 6 inches below heater element?
June 23, 2019 at 10:15 am #462103electrofix
Moderatorit will be one of the ones on top of the element
June 29, 2019 at 8:12 am #462104jtheobald
ParticipantHi,
Replaced the sensor which has the red dot as shown above but no difference, no you recommend replacing the other sensor next to it?
John
June 29, 2019 at 9:30 am #462105electrofix
Moderatoryou need to get a multimeter and just check the other stat on the element not the one on top the other one. if you put the meter on the ohms scale it should be zero ohms or close to
plus check the element for continuity
changing parts without checking can get very expensive if you had checked the stat you changed you would have found it was ok
June 29, 2019 at 2:02 pm #462106jtheobald
ParticipantThanks Dave, I get your point but as the sensor was only £18 I thought I’d give it a chance. The other sensor under the heater is 0 ohms. I am now wondering about the heater as even though the dryer goes for a couple of mins there appears to be no heat when I touch the casing.
June 29, 2019 at 3:52 pm #462107electrofix
Moderatorif you disconnect the heater and measure between the 3 large wires. the reading you get will be lowish. Expect under 200 ohms and very likely under 100 but as long as you get that sort of reading its ok. if its not it will be in the 1000,s
June 30, 2019 at 9:00 am #462108jtheobald
ParticipantDave, first of all, you have been fantastic, many thanks. I am getting a reading of 113.8 which seems to imply the heater is fine. I suppose the only thing I haven’t checked is the other sensor on top of the heater.
June 30, 2019 at 9:13 am #462109electrofix
Moderatordid you check all combination to make sure you get a reading on all wires
you have 3 large wires going to the heater so check
wire 1 to wire 2
wire 1 to wire 3
wire 2 to wire 3if any one of these do not give you a reading then heater is suspect
June 30, 2019 at 11:27 am #462110jtheobald
ParticipantYes, 28 (1.2), 85 (2.3). I am assuming I need all sensors connected but the heater element out of the machine?
June 30, 2019 at 12:26 pm #462111electrofix
Moderatorthat looks good you will prob find 1-3 is 50 to 60 ish
makes sense element ok and so are the main sensors
unfortunately its hard to figure out where to go from here
bosch tech info is hard to come by. as an engineer I would check the front and rear sensors but these are NTC’s which is a resistor that varies with temperature to see what value they give
