Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch and diplomat dishwashers
- This topic has 7 replies, 5 voices, and was last updated 18 years ago by
johno1998.
March 25, 2008 at 7:30 pm #35525
johno1998
ParticipantHi I have a fault with a Diplomat ADP8242 dishwasher it powers up then drains then fills and heats and washes and washes and washes, you can stop it and it drains OK then try and start it againg and still the same fault just wants to keep on washing. any ideas anyone ❓
Also have bosch dishwasher SGS69A02 GB/20 This one will do the whole cycle but gets down to the last 1 minute and the drain pump just keeps running even with the door open again you can reset it it does the whole cycle ok but still drain pump still running and 1 minute still on display HELPMarch 25, 2008 at 8:02 pm #246942gegsy
ParticipantRe: bosch and diplomat dishwashers
johno1998 wrote:Also have bosch dishwasher SGS69A02 GB/20 This one will do the whole cycle but gets down to the last 1 minute and the drain pump just keeps running even with the door open again you can reset it it does the whole cycle ok but still drain pump still running and 1 minute still on display HELP
The usual crud build up in the ribbed transfer tube,metering unit and if unlucky, the water matrix.
March 26, 2008 at 7:57 am #246943johno1998
Is that for both dishwashers ❓
March 26, 2008 at 8:20 am #246944gegsy
I did only quote the Bosch 😉
March 29, 2008 at 11:35 pm #246945eastlmark
ModeratorRe: bosch and diplomat dishwashers
johno1998 wrote:Hi I have a fault with a Diplomat ADP8242 dishwasher it powers up then drains then fills and heats and washes and washes and washes, you can stop it and it drains OK then try and start it againg and still the same fault just wants to keep on washing. any ideas anyone ❓
HELPneed to check it is reaching temperature, sometimes they cycle on a faulty thermostat (the one by the heater) and never reach full temperature, other than that its problably the PCB.
March 30, 2008 at 9:13 am #246946johno1998
Thanks for that will try 😆
April 3, 2008 at 10:07 pm #246947pod
ParticipantHi there had a problem with a bosh diswahser the other day left 1 min but would drain ok element was down to earth
April 4, 2008 at 8:15 pm #246948Jonah
Diplomat dishwasher is SMEG, if it no error code then i suspect PCB faulty
