Whenever I look for a bosch drain pump I come across part 1208028 which is sold as a “compatible” with bosh 00631200. These are used on many bosch dishwashers. My question is whether the 1208028 is as good as the original bosch and if anyone has had reason not to use it?
00631200 is the only one used from 2015 before that there was a 997 pump used aswell only 2 different drain pumps where used only that 31200 pump on all new models haven’t changed one in a long while, but I would fit genuine
kaibart wrote:00631200 is the only one used from 2015 before that there was a 997 pump used aswell only 2 different drain pumps where used only that 31200 pump on all new models haven’t changed one in a long while, but I would fit genuine
