Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Aquasensor fault
- This topic has 13 replies, 4 voices, and was last updated 19 years ago by
romi.
March 25, 2007 at 1:05 pm #26119
romi
ParticipantThis site has been really helpful so far today – thanks 😀
We’ve got as far as establishing that we’ve got an ‘Aquasensor fault’ on our Bosch SGS5302GB/07 dishwasher.
Is there anything we can do to reslove this ourselves or do we need to call someone in?
Many thanks for any further help you can offer.
March 25, 2007 at 3:28 pm #208875gegsy
ParticipantRe: Bosch Aquasensor fault
You don’t mention the fault you have, but have assumed aquasensor fault 😕 These sensors rarely cause problems IMHO.
If you can provide the fault, just so we can make sure that you have the right advice to procede 🙂Greg
March 25, 2007 at 3:36 pm #208876romi
Umm, not sure.
The display window (that shows which part of the cycle the machine is on when running) displays ‘1’ when we switch the machine on, and the machine doesn’t work.
Useful links on this site say it’s an aquasensor fault.
March 25, 2007 at 3:38 pm #208877gegsy
The useful links also say to clean the ribbed clear pipe from sump to metering unit aswell. Try that, power off of course 🙂
March 25, 2007 at 3:45 pm #208878romi
Ah hah!! Didn’t find that one…
Cheers – will try that then 🙂 (well, get him indoors to try that one…hehehe)
Thanks.
March 25, 2007 at 3:48 pm #208879gegsy
No problem 😉
March 25, 2007 at 6:13 pm #208880romi
🙁 Any idea about how to go about getting to the pipe – I’m afraid we don’t know how.
March 25, 2007 at 6:24 pm #208881gegsy
Remove front lower plinth to gain access to innards, pipe will then be visible 😀
March 25, 2007 at 6:28 pm #208882nomadPaul
first thing to do is electronically reset the machine – pressing two buttons together – normally indicated by ‘reset’ under/over two of the cycle buttons. If you have a fill prob , turning the machine on/off or opening the door doesn’t normally interupt the cycle – resetting will . If the appliance then starts working again , wait till it starts filling and listen out for a ‘kler-dunk kler-dunk’ sound . If this is heard , then a blocked ‘ribbed ‘ pipe or pressure chamber is likely to be the prob .
Search the site for Bosch dishwashers not filling or not heating and theres plenty of info aleady here.
good searching 😀
March 25, 2007 at 6:32 pm #208883romi
Thanks, guys. Got the plinth off, found the pipe, giving it a clean now…
Fingers crossed.
March 25, 2007 at 6:51 pm #208884romi
HOORAY HOORAY HOORAY 😀
Fantastic – clear pipe was full of hideous gunge, duly cleaned and reinstalled – and the machine now works.
Can’t thank you enough, Greg. What a hero! I always knew there was something about the Welsh… 😉
March 25, 2007 at 7:24 pm #208885Martin
romi wrote:What a hero! I always knew there was something about the Welsh… 😉
Sweet cheeses, now look what you’ve done….? 👿
He’s Welsh that’s true…but “a hero?”….blimey, that’s a bit strong and lord knows how that translates into Welsh so he may ever understand the true meaning….? :rolls:
March 25, 2007 at 7:37 pm #208886gegsy
A hero eh? Now you talking
March 25, 2007 at 7:44 pm #208887romi
Cymru am byth.
