Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Auto WAA24171 Flashing Rinse Light…
- This topic has 12 replies, 7 voices, and was last updated 14 years ago by
laurenceuk.
March 19, 2012 at 5:09 pm #68507
laurenceuk
ParticipantHi,
This machine is 3 years old – I sold it to a neighbour. 🙁
It’s the same type as the current WAE24060 Tactical, has selector dial, and a vertical line of 3 led’s for showing where the program is up to: from top to bottom… spin-rinse-wash.
When any program is selected the rinse light immediately begins a constant flashing (does it forever). The door will not lock and the machine will not start.
Turn machine off and on and the same thing.
Anyone had this problem. Looks like a board fault maybe.
Laurence
March 19, 2012 at 5:15 pm #371365scots
ParticipantRe: Bosch Auto WAA24171 Flashing Rinse Light…
Seem to recall I had this some time ago, could be brushes. Then you need to reset the board as the fault indication stays on.
Do a search here for how to reset the board.
Hope it helps
BrianMarch 19, 2012 at 5:35 pm #371366laurenceuk
Thanks Brian, will certainly check brushes but trying to do a specific search here is difficult.
Will make a fresh post to see if anyone knows how.
Laurence
March 19, 2012 at 7:36 pm #371367nomadPaul
Rinse light flashing is fault in drive circuit so definitely be looking at brushes / motor .
March 19, 2012 at 8:26 pm #371368Bernie
To reset try:-
Set selector switch to the 6 o’clock position hold the spin speed button (just keep your finger on the button), turn the selector switch one click clockwise 7 o’clock and after a couple of seconds release the spin speed button.
It may still show F21 if it has a display but then switch off and switch back on and it should clearMarch 21, 2012 at 8:00 pm #371369laurenceuk
Turned the selector to a program, pressed start button for 3 secs then turned selector to 11 o clock then off. Program selection back to normal.
Worn out motor brushes at fault. Changed a zillion motor brushes on Bosch but never had this happen before.
Thanks everyone for your support.
Laurence
May 22, 2014 at 5:51 pm #371370robbra
I’ve got the same problem but the reset hasn’t worked, changed pump, then brushes and still rinse light flashes.
Any more pointers as to what to check next?
RobMay 22, 2014 at 6:06 pm #371371Martin
robbra wrote:Any more pointers as to what to check next?
It is a motor problem so double check the continuity of the motor circuit.
May 22, 2014 at 6:22 pm #371372robbra
Hi Martin,
forgot to say I did check the motor and all on, hope it isn’t the boardMay 22, 2014 at 6:31 pm #371373Martin
Try reset procedure with motor disconnected. 💡
May 22, 2014 at 6:44 pm #371374robbra
That’s an idea I never thought of, will report back tomorrow.
May 23, 2014 at 11:50 am #371375timdowning
Had one of these the other day.
Just to let you know how I reset the fault;Dial in off position.
Hold down start button whilst turning dial anti one click.
Release start turn dial to off.
This should do it!May 29, 2014 at 8:18 pm #371376robbra
Lawrence and Tim……..It worked after several attempts. Thanks
It was a WAE24061 although search sent me to this thread.
Martin, didn’t need to disconnect the motor but will remember that for another time.
Rob -
