Hi, I’m not too sure on the fault codes for this type, but here goes. A few seconds after selecting prog, ALL of the spin speed leds, the rinse hold led and the wash led come on. Machine fails to start. Have tested door lock, motor circuit, pump, element, inlet valve. PCB has no visible problems. Any help would be much appreciated[/u]
Hi Martin, Not replaced door lock as yet. However I discovered if I removed the small 2 brown wired connector from the pressure switch, then turn machine on, the door will lock but with still the same outcome. Have discovered a previous post with exactly the same symptoms with diagnosis of pcb.
