I don’t suppose anyone’s been able to get hold of one of these from anywhere have they ?
Bosch WFB2004GB/16 bearing seal. The diagram on quickfinder only shows the whole crosspiece so I phoned BSH who confirm that you can’t buy the seal alone, so it’s £130 for the whole thing or nothing !
It’s not part number 036071 either, I already made that mistake, that’s the thermostat grommet 😉
Sorry Dave, as far as I know not available as seperate item, this bearing spider was also used on some Caremark / Homark machines and they could not get then either. 🙁
Unless Woz knows different ❓
Just checked on BSH web site complete spider 26 3726 is listed at £107.18 inc vat retail.
On a previous thread somebody did suggest trying bearing suppliers but no reply with result was posted.
Regards
Sparkey
Maddocks do a Blomberg bearing seal that’s virtually identical apart from the outer extra lip is not quite as wide but the general dimensions are the same (shaft and housing).
I’ll order one and see if it does the job, as it’s only 63p 😯 it’s worth a try.
