Bosch Bent Hose End Replacement Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Bosch Bent Hose End Replacement This topic has 2 replies, 2 voices, and was last updated 12 years, 4 months ago by Stompa. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts November 12, 2013 at 12:57 pm #78064 StompaParticipant The bent hose end on my Bosch BSF1103GB/04 vacuum cleaner has snapped and needs replacing, one of these: http://www.espares.co.uk/product/es108407/bent-vacuum-cleaner-hose-end?PartTypeId=1573&ManufacturerId=856 Having looked at the old one though, it’s not at all obvious how you separate this hose end from the hose itself. Does anybody know how this is done? Thanks November 12, 2013 at 3:29 pm #404334 donModerator Re: Bosch Bent Hose End Replacement Hi Bent end is usually held by two small pips which need to be depressed at the same time for the bent end to be released. HTH 🙂 Don November 12, 2013 at 5:51 pm #404335 StompaParticipant Re: Bosch Bent Hose End Replacement don wrote:Bent end is usually held by two small pips which need to be depressed at the same time for the bent end to be released. Thanks, I’d tried that before without success, but having just tried again it’s worked. Many thanks Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
