Bosch Brush fitting – which direction?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Brush fitting – which direction?
  • #39934
    Tarian
    WFL 2260
    I removed the old brushes (which were very short).
    The new brushes have a taper – so have to face the right direction
    Unfortunately the old ones sprung out so quickly I’m unsure which way.
    Does the spindle / axle rotate anti-clockwise or clockwise?
    (Should the brush faces be O or /O/ )
    Thanks very much
    #264192
    timdowning
    Re: Bosch Brush fitting – which direction?
    What ever way sounds the smoothest!!!
    You will know when you even turn the motor pulley by hand!!
    Make sure machine is unplugged when refitting motor / parts!!
    #264193
    Tarian
    Thanks for the amazingly quick reply….
    Turning the spindle either way produces a slight rubbing sound – but equal.
    Looking from the brush end, should they be O or /O/
    #264194
    gegsy
    I usually do one at a time.
    Turn motor spindle by hand and if it sounds and feels like a jackhammer, remove brush and turn round.
    HTH
    nomadPaul
    If you look at the brush , it will have one side longer than the other . This longer side goes on the same side as the connector that attaches to the brush itself .
    i.e If the connector comes in from the right hand side , then that the longer edge of the new brush
