Bosch class 1xx leak problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch class 1xx leak problem
  • #71270
    Banquo
    I have a problem with my Bosch class1xx dishwasher, having not run for a couple of months i put it on eco program. Later when i returned the check water light is on and a strange noise from the machine. The wash cycle had not completed and on pulling out the machine to check if the water was turned on (it was) i discovered water leaking from what appears to be 2 small openings at the rear of the machine. Filter checked ok, any ideas much appreciated
    Banquo
    #380555
    Re: Bosch class 1xx leak problem
    from what you described the base has flooded and the sound you are hearing is the water punp running to stop any further leaks
    there are a number of things that can cause it
    foaming due to exess or wrong detergent
    leaks either through component failure, dirt on seals or even mice
    you need to drain base and run it again after cleaning door seals etc and watch for water leakage in the base
    Banquo
    Many thanks for your informaton, hmmm is there a drain plug somewhere or do i just have to tip it over and let the excess water out somehow?
    #380557
    some machine you can tip but you have to be careful you dont get electrics wet
    best way take a side off and mop it out
