Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Classic 1200 express cutting house power
- This topic has 44 replies, 2 voices, and was last updated 6 years ago by
shadzuk.
April 5, 2020 at 2:30 pm #97424
shadzuk
ParticipantMy Bosch Classixx 1200 express started cutting off power about 15 minutes into a wash. After disconnecting the element it’s going, could I have the part no. to order a Bosch Classixx 1200 express heater element please.
April 5, 2020 at 2:32 pm #467659shadzuk
ParticipantAny help with further testing also appreciated, due to only able to disconnect it and measure it at this time or if there’s anything else I need to check please?
April 5, 2020 at 2:44 pm #467660electrofix
Moderatorwell the element has caused it to trip
any other noise in the machine recently?
need the complete Enr number inside the door to be able to get part no (like wae24166gb/05)
April 6, 2020 at 10:43 am #467661shadzuk
ParticipantSeemed a little noisy on the spin,other than that it worked and completed the cycle. Many thanks for your help,the details inside the door are E-Nr. WAE24162GB/03 FD 8605 604280,where can I find the part and cost please? How long will it take to arrive, really desparate for this to work
April 6, 2020 at 11:09 am #467662electrofix
Moderatorno problem
machine was made may 2006 just for your interest
heater
https://shop.ukwhitegoods.co.uk/d321400as-compatible-washing-machine-heating-elementsince you cant use the machine before you order take out the old element and look for mechanical damage. What i am trying to make sure is there is nothing wrong with your drum before you put in a new heater. what can happen is the drum spider fails and on spin the drum can catch the heater and wear through the metal causing a short. So look for signs of contact about two thirds down the heater
April 6, 2020 at 6:52 pm #467663shadzuk
ParticipantMany thanks for your great help, I ordered the part and will remove and take a look
April 13, 2020 at 9:19 am #467664shadzuk
ParticipantHello many thanks for the part,now I got difficulty fitting it at the moment unsure if I need to locate any drum retaining clip at the front of this machine, I have removed the panel/screws at the bottom to ease the front away,but now wondering if I am going about this the wrong way. Noticed rubber off the seal on the inside of the drum and on a spin knocking and noisy this time. Anything I need to check,with regards to the noise?
April 13, 2020 at 9:34 am #467665electrofix
Moderatordont have to trmoce drum to remove element
undo nut in the middle of old element and leave nut just on the end of the thread
tap nut with pliers or small hammer. This releases pressure on the seal. you will then have to carefully prise it out. can be a challenge, the importent but is not to damage the tub whar it seals.
once its out check there is no rubbish in the bottom of the tub, then insert the new heater and tighten the nut. be carefull to tighten it enough to seal but not too much as the bolt can snapassume you know the complete front of the machine comes off for access
April 13, 2020 at 10:05 am #467666shadzuk
ParticipantThank you for your help,but upon about to change it I noticed your replacement is much shorter,is it the correct one? I tried attach a photo for you,but size is too big 16k for a photo?? Any help appreciated
April 13, 2020 at 10:44 am #467667electrofix
Moderatorgen element part no is
12029196so gen element is here
https://shop.ukwhitegoods.co.uk/00623503-washing-machineheating-elementnon gen equivalent is
https://shop.ukwhitegoods.co.uk/d321400as-compatible-washing-machine-heating-elementhow much difference in the 2
as long as the end of the element fits in the holder inside the tub so it cant move should be ok
April 13, 2020 at 10:55 am #467668shadzuk
ParticipantLooks around 1.5 inches shorter,sure this is right?? Got anywhere I can send you a photo?
April 13, 2020 at 11:03 am #467669electrofix
Moderatoram trying to find out
have sent a message to admin am trying to find out if the site may have got a wrong link
looking at another source i get
https://shop.ukwhitegoods.co.uk/htr72-bosch-washing-machine-heater-element
as eguivalent. Is your old unit 265mm long ?Dave
April 13, 2020 at 11:11 am #467670shadzuk
ParticipantYes around that and the other one is around 230mm. Where are you measuring from and to please?
You insisted I gave you the information from inside the door to ensure this way I received the correct part I assume,how could you possibly get this wrong. I really need this fixed today,I can’t wait forever for a washing machineApril 13, 2020 at 11:16 am #467671electrofix
Moderatori assume its total length but its not my measurement its taken off the site shop
i am at home so, may have one in work but wont be able to measure till tomorrow , provided i have one
it lists the element you bought as 225mm if that helps
dave
April 13, 2020 at 11:24 am #467672shadzuk
ParticipantWill it work or blow my machine or too short to do anything, the element is around 40mm shorter, the orginal I removed is around 265mm,but surely the door information you requested tells you that?
