Re: Bosch classic WTL6102GB/02
Easy peasy.
remove side panel and rear heater cover. Drop the front access flap. Undo nut on front fan.
Drop main belt off (if not already off) remove tension spring etc that sits next to pump.
Remove motor wiring, then pull the big plastic handle off of motor this is what holds the motor in place.
Once that’s off just pull the motor backwards to give access to fitting belt.
The motor must be in the correct position in order to refit the “handle”.
Shouldn’t take more than half an hour to do 8)
HTH
