Bosch Classicxx 1400 Express – drum not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classicxx 1400 Express – drum not spinning
  • #79109
    Shades
    E-Nr. WFO2866GB/07 FD 8501 606488 BOSH CLASSIXX 1400 EXPRESS
    OK I have looked a few things already and am looking for advice on how I should proceed. The washing machine is over 10 years and has operated faultlessly until now.
    firstly there are no error codes, that I can see, it seems to work as always but motor is not turning the drum. They will turn by hand. I removed the motor and found the brushes were worn down to about 5mm in length so got some new ones, cleaned the carbon off the commutator, and refitted. Still no joy with the motor.
    Could it be the motor, can I test it easily to see if it is.
    Is there a diagnostic setting I can put the machine in see if it will tell me the problem. Found some instructions online to rest fault codes but doesn’t seem to have the bottom and lights it was referring to.
    Any help would be appreciated before I have to rule out getting it repaired and spending £300 on a new one.
    Thanks.
    #407974
    Re: Bosch Classicxx 1400 Express – drum not spinning
    There is a thermal fuse on the brush ring unit so that made have tripped. Easy to check, just test for continuity between the motor plug connections.
    #407975
    Shades
    Do Do you mean the contacts in the plug socket on the motor. A few hints on the pins to test would be helpful. Thanks.
    #407976
    Nice pic!
    #407977
    Shades
    Thanks. Always helps on a forum.
    So Ill assume it across pins 1_2, 1_3, 1_4 and so on.
    #407978
    Shades
    So it the bottom pin is pin 1 I have continuity between 1&2 1&3 and 2&3. Does this mean the thermal fuse is OK?
    #407979
    There’s 8 pins I see in the pic so you should have continuity between them all. By that I mean each pin should have continuity with at least one other.
    #407980
    Shades
    There isn’t continuity between any of the rest of the pins. Does this mean the motor is now an expensive paperweight? and replacing a motor on a 10year old plus machine would be false economy?
    #407981
    Not good news for sure. I did suspect a failing there hence why I asked the question . 🙁
    #407982
    IWANTBLUE
    any update on this shades?? whilst I have a different Bosch machine , 1400 Exxcel, I suspect the motor is the same, and I have a similar issue in that mine will now spin, but for reduced time , and noisey/arcing.
    Is there an online drawing for the pin outs Martin? I noticed my last pin is not connected however…
    #407983
    IWANTBLUE wrote:mine will now spin, but for reduced time , and noisey/arcing.
    Your motor’s armature is buggered! 🙁
    #407984
    IWANTBLUE
    OH 🙁 ….
    I guess I’d better strip it out again and check then 🙁
    Is there any check I can do from the plug/terminals? or is it strip it right out to check across the com bars individually?
    I was going to replace the bearings while I had it out to change the brushes, but was worried about what I assume is the speed feedback circuit/tacho, as the wires were hairlike….. so I would have checked it out if I had, but as everyone says, when it’s your own, there’s a pressure on your shoulder suggesting it needs to be back together 😉
    If I can’t do anything from the pins, I’ll strip it out tomorrow morning 🙁 I’ve got my multimeter here but no Megger, but I gather from your statement I’m not likley to need the Megger 🙁
    Cheers(for the bad news….)
    Nick
