bosch classix dishwasher check water light
Home Forums Public Support Forums Help And Support Dishwasher Help Forum bosch classix dishwasher check water light
  • #59821
    simon1980
    hi, i have been trying to eliminate the fault with my dishwasher, it fills up and the the pump drains out, but then it fills up and then drains out a bit, then fills up and so on, after about 2 or 3 mins the check water light comes on,
    it does this on all settings. I have checked the drain float and filter etc, is there another float switch inside that could be gunked up and not telling the machine its ready to go?
    simon 🙁
    #339743
    CJAPeterborough
    Re: bosch classix dishwasher check water light
    If you post the ENR for the machine then folk will be able to more specific.
    Most likely you need a new jug impellor(if your model controls the water flow into the machine this way).
    Plenty of threads on this as it is a common fault.
