Bosch classixx 1000 express wont spin.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch classixx 1000 express wont spin.
  • #31139
    dentonholme
    Hi this has been making abit of a noise for a few days,today when i went to empty it the washing was still very wet,put it on to spin and drum is not turning round.It is e-nr-wfl2066gb/01 fd 8404602129 model.HAve tried to remove the pump cap at the bottom to see if there is a blockage but can only turn it very slightly,any ideas how to get this out scared i am gonna break it or make it worse,thanks .
    #229822
    gegsy
    Re: Bosch classixx 1000 express wont spin.
    You will have to drain the tank down with the little drain tube first.
    The main filter cap is probably jammed because of some foreign object and undoing it may (most probably IMHO) destroy the inner of the filter.
    Take your time and you may get away without damage 😕
    ProgRob
    Hi all,
    I have the same machine (Classix 1000 Express, WFL2066GB/01) with an identical problem. Had a bit of a noise over the last few days at times. Tonight, went to the machine and the clothes are all wet. Have run a rinse cycle (and also a spin cycle) and identified that the drum does not turn at any time. The machine appears to fill and drain OK though.
    Have opened up the cap at the bottom and lots of water came out. I can easily turn the little blades within.
    Any ideas? Is it the same problem as already explained? If so, how do I identify the parts to get to in order to clear the object as I am getting some kind of error through the Bosch spares website so cannot see the exploded machine diagram.
    Any help gratefully received,
    Thanks,
    Rob
    #229824
    ProgRob
    Drum Not Turning
    The machine is still filling and then doing nothing at all regarding washing or spinning- i.e. the drum is static. Listening to the machine there is no attempt by the motor to turn ( i.e. no sound at all). I fear the motor has gone and a new machine must be purchased tomorrow. Can anyone verify this is the case?
    #229825
    nomadPaul
    You might get away with a set of new brushes for the motor. Its the most common problem with motors but you will need to remove the motor and then the brushes to check. They will have worn down to a mere stub and then you have to hope that they havn’t damaged the motor commutator.
    #229826
    GeoffCh
    I have another problem with my Bosch Classixx 1000, which I will post separately. However I had to remove the filter cap, which was stuck. From internet forums I learnt that there wouldbe something in the filter (or the pipe from the pump) blocking it from turning more than 90 degrees (in my case a nail).
    Put the machine on its side and release the rubber hose from the filter, using pliers to hold open the spring clip. Fish out the object and replace the hose.
