My washing machine drum wont spin and someone said that it might be the brushes, so im trying to get at them to check them, I was told to remove 2 bolts and the motor should just come forward but not having any joy, I have attached 2 pics if anyone has any ideas, thanks.
Mark , as Penguin sayd , you’re practically there . Get a big flat headed screwdriver and insert it between the motor and rear tub just behind where you took the two big bolt screws out from the back . It’ll just need levering off…..
One point , when you remove the brushes , make a note of which edge went on what side as they will be slanted .
Thanks for the help I manged to lever the motor off to the side with a big screwdriver, for some reason last night I thought the motor would come off towards me.
