Bosch Classixx 120 Express won’t switch on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classixx 120 Express won’t switch on
  • #75685
    timardizzone
    I wonder if anyone can suggest a solution to this problem:
    The motor had stopped working but machine was still running through cycle. I checked the carbon brushes and replaced them when I found that they were worn to stumps. Once I have reinstalled the motor, it started briefly, but made a slightly odd sound and then stopped again. I took the motor out again and found that I had installed one of the brushes the wrong way round. After reinstalling, I now appear to have a dead machine. The LEDs on the panel flicker on briefly when switching on but after that, nothing.
    The model number inside the door is WFO2467GB/01.
    Any help or suggestions would be greatly appreciated.
    Thanks,
    Tim
    #395848
    Re: Bosch Classixx 120 Express won’t switch on
    You need to test the motor with a suitable megger or multimeter. The chances are that the motor overload has blown, possibly taking out the main pcb as well. 🙁
    #395849
    timardizzone
    Hi Ian,
    Thanks for replying. Is there a reset for the motor overload or would it mean a new motor? There is frustratingly little information available on this things. I expect that blown PCB would make repair uneconomical.
    Tim
    #395850
    Both the motor and the pcb are very expensive on their own, no reset for the overload .:(
    #395851
    Allsorts
    The PCB’s are relatively easy to repair.. Sometimes you can get away with just track repair
