Re: Bosch Classixx 1200 Express
I’ve just got the covers off & my multi meter out.
Everything looks dry in side and I can’t see any sign of moisture.
I changed the 3 ping plug and put it on a circuit on a new consumer unit – the RCD trips and takes the panel out – earth problem then?
Looking at the machine, if I put my meter across the right hand terminal of the heater (after taking the spade connector off, I get a resistance reading between that terminal and the earth spade. I also get a resistance reading between the thermostat terminal and earth.
I’m assuming that anything to earth should really be open circuit and this is wrong?
The heater is brand new and has only done a couple of washes
