Bosch classixx 1200 express
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch classixx 1200 express
  • #74704
    erdo666
    When I try to turn machine on all the lights come I. I have cleaned the filter at the bottom of the machine, but the lights are still flashing and it does not work. Any suggestions, please?
    #392581
    Re: Bosch classixx 1200 express
    What’s the model number (Enr no.) as there’s 100’s of them?
    #392582
    erdo666
    WAE24162UK/08.
    Type WCM40 IPX4
    #392583
    Programmer error of some kind. Have you had any power supply problems recently (power cuts etc)?
    #392584
    erdo666
    Quick power the other day. But this happens a lot and usually the machine is fine.
    #392585
    erdo666 wrote:Quick power the other day. But this happens a lot and usually the machine is fine.
    Hmmmmm? Thought so, hence why I asked. The programme module needs looking at as I think a power surge may have damaged the PCB?
    #392586
    erdo666
    Does that mean I need to call someone out, or is this something I can do. I’m not mechanically minded but will give it a go!
    #392587
    As I said earlier the programme module will need looking at. As indeed the rest of the machine would be if you call out a local independent repairer. That may be your best option considering. Look HERE for someone in your area. 😀
    #392588
    erdo666
    Thank you. Have put in a call to our local team. Thanks for your help.
