Bosch Classixx 1200 Express Conditioner Problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classixx 1200 Express Conditioner Problem
  • #30755
    Stuart264
    I have a 12 month old Bosch Clasixx 1200 Express (Model Number WAE24162GB/03) that every time I finish a wash the fabric conditioner container is full of water.
    This is my third Bosch so I know that it its usually the pipe in the drawer thats blocked but its perfectly clean and I am really scratching my head as to whats causing it.
    Any ideas?
    #228298
    msappliance
    Re: Bosch Classixx 1200 Express Conditioner Problem
    make sure that the pipe is fully pressed down or the water wont syphon fully.
    #228299
    richardable
    are you using the same conditioner all the time, is it a real make or a supermarket version, are the holes at the top inside the dispenser clear or is there a build up of old conditioner there? if there is try a long handled pan scrubber brush to try and clean it. if you do have a build up of residue which blocks the holes then the best fix is get a replacement dispenser top.
    richard
    #228300
    nomadPaul
    As richard said , look up into the roof of the detergent drawer area , where all the holes for the water comes out . You should see 4 squarish holes , in the middle , about 4 or 5cm’s from the front . These are probably blocked with black mildew . You can try and clear these out using a cable tie , pushing it into the holes and ‘rodding’ it a little to clear any muck .
    You should also read these articles as they are full of good info
    http://www.ukwhitegoods.co.uk/help/fix- … awers.html
    http://www.ukwhitegoods.co.uk/help/clea … hines.html
