Bosch classixx 1200 express hot rinse
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch classixx 1200 express hot rinse
  • #85450
    derekcogle
    I have had a bosch classixx 1200 express for 10 years, this week the clothes warm to hot after rinsing. It has only a cold water feed.
    I have cleaned out the powder softner drawer and ran some sodium crystals through the machine. I have read on some other advice sites that it could be a relay on the control board that can cause this, if it is, are the boards expensive or is it possible to identify which relay is causing the problem?
    #428645
    The boards are prohibitively expensive though if you’re experienced in electronics it is do-able. What is the model number of the machine anyway?
    #428646
    derekcogle
    Re: Bosch classixx 1200 express hot rinse
    Martin, my model number is E Nr WAE24162GB/03 FD 8609 619374
    I could replace the part if I knew which component it was.
    Is it likely to be the control board? the water comes in and drains away okay, I do not know what else would cause the rinse water to be hot
    #428647
    It’s the Control Board.
    #428648
    derekcogle
    thanks Martin, it looks like a new washing machine
