Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Classixx 1200 Express: Trys to draw water but can’t??
- This topic has 5 replies, 2 voices, and was last updated 9 years ago by
borderfox100.
March 24, 2017 at 5:06 pm #90905
borderfox100
ParticipantMy last wash using this machine came out wetter than what it should.
Just stuck on another wash. It makes that sound that precedes it filling with water – but stops after half a second – abruptly. It’s continuing to attempt that after every pause in between rotations.I got the impression there may be some water not draining out of the unit previously – but then there doesn’t seem to be enough water in the unit (or at least, what I’d normally observe during a wash cycle) now that the machine is running.
Any ideas what this could be?March 24, 2017 at 5:22 pm #446417Martin
ParticipantRe: Bosch Classixx 1200 Express: Trys to draw water but can’
Please provide us with the full model number (ENr number) shown inside the door and on the back panel.
March 24, 2017 at 5:58 pm #446418borderfox100
E Nr. = WAE24162 UK/01
March 24, 2017 at 7:08 pm #446419Martin
borderfox100 wrote:My last wash using this machine came out wetter than what it should
First thing to try is to check the drain filter is clear. Use the drain tube to drain off any residual water first then carefully unscrew the filter cover anti-clockwise.
March 25, 2017 at 3:32 pm #446420borderfox100
Thanks Martin.
I drained it – then cleaned the filter. There were a couple of pennies in there – nothing else. Replaced filter cap – then ran wash again. It goes straight into ‘wash’ mode immediately – rather than fill tub with water. Once in wash mode, when the tub pauses, it makes a noise as if it’s trying to pump water into it. This action ends abruptly/unsuccessfully. It tries to do this each time.
Do I need to check the pump itself?
March 25, 2017 at 4:42 pm #446421Martin
borderfox100 wrote:Do I need to check the pump itself?
You’ll need to do more than that and check the sump hose isn’t restricted in any way and that the air hose and chamber attached to it are also clear of the dreaded ‘gunge’.
