Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Classixx 1200 – Fills with water and then stops.
- This topic has 8 replies, 3 voices, and was last updated 17 years, 2 months ago by
qprfcmark.
January 11, 2009 at 2:05 pm #42483
qprfcmark
ParticipantHi,
My Bosch Classixx 1200 fills with water from the cold water feed on all cycles but then stops and does nothing further apart from the sound of a click at about 40 second intervals coming from the control switch. Drain cycle works, but spin and rinse do not.
The details on the label inside the front loading door reads:
E-Nr WFL2462GB/12 FD 8210 606995.
Any ideas as to the problem?
Mark.
January 11, 2009 at 2:39 pm #273655Penguin45
ParticipantJanuary 11, 2009 at 2:47 pm #273656qprfcmark
ParticipantRe: Bosch Classixx 1200 – Fills with water and then stops.
Thank you Penguin45 for the quick response and links! Will let you know outcome!
January 12, 2009 at 10:51 am #273657qprfcmark
Penguin45……….Do you have any step by step instructions / diagrams on how to remove the motor on this model? Thanks
January 12, 2009 at 2:51 pm #273658qprfcmark
qprfcmark wrote:Penguin45……….Do you have any step by step instructions / diagrams on how to remove the motor on this model? Thanks
Just worked it out…………..
1: Tilt machine to access underneath of machine.
2: Remove earth cable and live connections from motor.
3: Stand machine upright and remove rear panel at back of machine by undoing screw at bottom of panel.
4: Remove drive belt from motor via removed rear panel.
5: Remove 2 retaining bolts holding motor in place via rear panel.
6: Pull motor towards rear panel and motor will fall out of place.
7: Remove 4 long screws holding motor together.
8: Remove Carbon Brushes and replace.
9: Assemble in reverse.Regards
Mark
January 13, 2009 at 12:14 am #273659Penguin45
Well done. I’m out repairing during the day, so can’t answer posts.
June 11, 2009 at 10:29 pm #273660gavingolf1
hi,
got the same issue on this machine.
changed the brushes that were down to 6-8mm but still no joy.Hope you can help
thksJune 12, 2009 at 12:50 am #273661Penguin45
Test meter – circuit across the armature should read 5/6 ohms.
June 12, 2009 at 11:05 am #273662gavingolf1
Thks for coming back.
Armature reading was as you suggested at 5.8 ohms.Anything else you can suggest?
thks
Paul -
