Bosch Classixx 1200 Washer – no lights
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classixx 1200 Washer – no lights
  • #75990
    hyphensmythe
    Bosch Washer Classixx 1200 Express model WAE24162UK/1
    The machine was put on its side, water and power disconnected, for resolution of a drain pump problem. The sump hose was removed and disconnected from the two small plastic hoses, one for emergency drain, the other under the drum for one of the interlocks (?). The sump hose was cleaned out and refitted with both small hoses. The machine is now on its feet again with power and water reconnected but there are no lighta on the fascia. Power to the machine and to the back of the front panel is confirmed.
    What may be the cause of the problem and its solution?
    #396891
    Re: Bosch Classixx 1200 Washer – no lights
    If you leant it on its right hand (filter) side then most likely water has got into the electronic control module? Or the pressure switch (on the same side) has been compromised?
    #396892
    hyphensmythe
    Thanks for the reply. I was careful not to allow water anywhere near the electronics. After leaving it to “rest” for four hours it is now working, so is there something that needs to settle down after being disturbed?
    #396893
    Probably water in electronics has since dried?
