Bosch Classixx 1400
  • #86144
    AlanJW
    I have the above m/c with a defective heater (puts trip out)
    Can the heater be accessed sufficiently for replacement?
    Access looks very restricted!
    Alan
    #430412
    Re: Bosch Classixx 1400
    You didn’t bless us with the actual model number but usually on many Bosch washers the heater is accessed after the front panel is removed.
    #430413
    AlanJW
    Thanks for your quick response. Sorry! It’s WF 02867GB/17 but how does the front come off?
    So far I have done my metering from underneath and was hoping to withdraw the heater but now realise that it is quite long!
    Alan
    #430414
    Remove control fascia, bottom kick panel and unhook door boot clamp ring. The rest is obvious 😉
    #430415
    AlanJW
    Thanks for that, our previous m/c’s have been accessible from the rear so have been quite get attable.
    Heater on order!
    Alan
    #430416
    AlanJW
    Heater arrived and I was most impressed at the build of the Bosch.
    Heater came out OK but I was amazed at the amount of scale surrounding the element (causing localised over heating and the failure) Hopefully when I give it a test run the majority of this will be pumped out.
    Would it be a good idea to run a descaler through it or is that likely to cause more problems?
    Alan
    #430417
    Forget the descaler and just hope the pump doesn’t jam up trying to clear that muck away!
    #430418
    AlanJW
    Put it through a cycle and all works fine!
    Thanks to all for your advice.
    Alan
