Bosch Classixx 1400 Express Wont fill properly
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classixx 1400 Express Wont fill properly
Viewing 1 post (of 1 total)
  • #54857
    Hi all,
    i have a Bosch Classixx 1400 Express which is not filling sufficiently.
    Water pressure is good, in line filters ok. It is not filling sufficiently to wet/wash the clothes. I checked the air pressure switch and is working ok, but seems to be shutting off water supply early. I took it apart and rubber diaphragm seems good. I ran a cycle with it apart and pressed the mechanism when there was sufficient water, let it run for a bit and released the mechanism, started adding more water until i pressed mechanism again. All ok. Is there a way to adjust the pressure switch via screws with tamper proof pain or is the unit suspect? Blew through tub and seems to be clear. or would i be better off buying a new unit?
    Many thanks for any help.
    Eamonn
