Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Classixx 1400 washing machine stopped heating water.
- This topic has 6 replies, 3 voices, and was last updated 14 years, 10 months ago by
jsykes.
June 10, 2011 at 6:40 pm #63310
jsykes
ParticipantHello there,
My Bosch Classixx 1400 (WAE281) stopped heating water ever since I moved house. It completes the cycle fine though.
Naively I replaced the washer element only to discover this did not rectify the problem. Can anyone suggest what else could be causing the problem? I did recently move house and the washer may have received some knocks.Any advice would be greatly received.
June 11, 2011 at 7:40 am #353416Martin
ParticipantRe: Bosch Classixx 1400 washing machine stopped heating wate
jsykes wrote:stopped heating water ever since I moved house……..and the washer may have received some knocks.
Based on that information I would venture to suggest a wire or wires may have become disconnected or worse still that the control module may have suffered irreparable damage? 😕
June 11, 2011 at 10:22 am #353417jsykes
Thanks for your reply.
If some solder has come loose from the control board is that something I could see? I’m reluctant to give up on my washing machine just yet so any further advice on things I could try to fix it would be greatly appreciated.Thanks,
June 11, 2011 at 1:02 pm #353418electrofix
ModeratorRe: Bosch Classixx 1400 washing machine stopped heating wate
have you tried it on a very hot programme that way if it does heat you can feel it
not sure how this machine handles no heat some machines stop and wait other machines like Zanussi move through prog even it heater does not worklong shot i assume where you lived before it was plumbed into cold water. as a test if you are unsure was the washing still warm at the end of the programme?
June 11, 2011 at 2:57 pm #353419jsykes
Thanks.
The machine is cold water filled. It seems to complete a wash cycle just fine but the water is definitely cold, even on hottest wash. I do wonder if the thermostat might be broken?June 11, 2011 at 3:20 pm #353420electrofix
thermostat on these machine is electronic normally mounted on the heater check for broken wires
seems very strange that it heated ok before the move and not after you are sure it was not plumbed into hot water in old house by mistake ( get that all the time been to a lady a few weeks ago had machine plumbed wrong way round for over 10 years ) in old house if clothes were warm at the end of wash then thats it
you can check board for contact damage around heater relay. it could be heater relay failed
there is so many if’s that unless you know what you are doing it gets complicatedDave
June 12, 2011 at 8:03 am #353421jsykes
Many thanks for your advice.
