Bosch classixx 6 start light flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch classixx 6 start light flashing
  • #88376
    bmrenr
    Hi I have the above washing m/c and it had lights 1,3&5 flashing. I checked the brushes and they needed changing so I did and then reset the m/c but now when I select a cycle all that happens is the start light keeps flashing. Usually when you select a cycle one of the spin speed lights light up and the start light flashes until you press it but now none of the spin speed lights light up. Has anyone come across this before.
    Tom
    #437842
    Re: Bosch classixx 6 start light flashing
    Giving us the model number would help enormously. 😉
    #437843
    bmrenr
    Sorry Martin its
    Enr wae 24164gb/22
    Tom
    #437844
    Well the error code was indeed the motor fault so you might try disconnecting the motor plug and try resetting again? You may need to carry out several resets with the motor plug connected and disconnected.
    #437845
    bmrenr
    Cheers Martin its the first time I’ve come across this I’ve had problems in the past actually clearing the error code but once I did it worked away no problem.
    Tom.
    #437846
    bmrenr
    You were right Martin went back to house today and on second try resetting it worked. I had tried this so many times yesterday luckily it was a local call. Thanks for the help.
    Tom.
