Bosch Classixx 7 keeps stopping
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch Classixx 7 keeps stopping
  • #97796
    elmana
    Hi.
    I have a Bosch Classixx 7 (WTV74105GB/13), which keeps stopping after about 10-15 mins with the Filter/Vent Hose light coming on. I can hit start again and the same things happens. I’ve cleaned everything. I’ve also run the diagnostic and the Iron Dry/Cupboard Dry lights come on together. Any idea what I need to do to fix it? Thanks in advance!
    #469554
    Mihangel
    Might be worth checking the actual outlet (outside) to make sure it’s clear and unobstructed
    #469555
    elmana
    Thanks. Already given everything a clean and ensured not blockages, but that hasn’t helped.
    #469556
    is it heating ?
    elmana
    Yes. Heats fine until it stops. Once I press start again, it heats again for 10 mins or so before stopping.. and things continue this way..
    #469558
    when it stops does it fault out or just stop the programme as if its dry
    elmana
    Sorry, I should have been clearer. When it stops the anti-crease/end button lights up
    #469560
    sop that sounds like it thinks everthing is dry
    try a timed programme and see if it will run the course
