Bosch Classixx Model No SGS45C02GB/06
This machine stopped through mid cycle 43 mins and is chowing the “Check Water” fault.
The water drains away and I have tried filling the dishwasher back up with a jug and it still drains away but the Check water is still showing.
Water is being supplied to the machine and the pump is constantly on.
NO matter what program I set the dishwasher to I cant change the 43 mins that it shows on the timer, I have turned it off from the wall and back on again bit the timer still shows 43mins, the pump is still going and check water shows.
I have checked the filter in the bottom of the dishwasher as shown in the user manual and that is clear, there is also a white tab that can be lifted to check the impeller and I see the impeller spinning round.
The machine seems to be draining OK but the timer is still stuck at 43 with the errors shown above.
If I open the door the lights go off on the front of the dishwasher but the pump stays on
Any ideas as to what I should be looking for.
Thanks in advance
Uncle
