Bosch Classixx Condenser Dryer WTL6003GB Pump
Home Forums Public Support Forums Spare Parts Help Bosch Classixx Condenser Dryer WTL6003GB Pump
  • #18610
    albacore
    I have the above model (described as infamous on another section of this forum(!) – in view of interior access difficulties – I can go along with that!). Anyway it stopped pumping out the condensed water, flooding the sump and eventually fan housing.
    Traced to the pump where a little plastic clip at the end of the motor shaft had dropped off, releasing an o-ring which then jammed in the impeller. I managed to reassemble and everything worked OK for a while but now it’s stopped pumping again, so I assume the pump is u/s again and obviously needs a new one.
    A source cheaper than Bosch appreciated. I believe this is a badged White Knight, so perhaps an alternative route?
    TIA,
    Albacore
    #179622
    Re: Bosch Classixx Condenser Dryer WTL6003GB Pump
    Pump from Bosch is p/no 142142 @ £53.81 plus VAT
    Pump from White Knight is 4213 092 25211 – about £35 from memory, which has to be a bit better 😀 . Email with p/no to spares@ukwhitegoods.co.uk for confirmed price and ordering.
    albacore
    Many Thanks, Penguin45!
    Albacore
