Bosch Classixx dishwasher E-Nr SGS43C02GB/35
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Classixx dishwasher E-Nr SGS43C02GB/35
  • #53777
    jontymox
    Good afternoon,
    The above dishwasher begins its cycle well; i.e. lets water in, and pumps water around internally. (water pressure appears high, circulation pump working)
    However, after draining the initial dirty water, the m/c then refuses to carry on through its cycle.
    I don’t know where to start looking, as the main functions work for a while and then stop!
    Could someone advise on a test procedure for this fault please?
    Kind regards,
    jontymox
    #317184
    Re: Bosch Classixx dishwasher E-Nr SGS43C02GB/35
    BUMP. 😉
    #317185
    jontymox
    Thanks iadom,
    I’m wondering if it’s the control module, as I’ve tried a new inlet valve to no avail.
    The m/c works initially, then stops and is dry!
    jontymox
    #317186
    gegsy
    Does it stop silent,humming,lights showing etc
    jontymox
    Yes, it does so!
    jontymox
    #317188
    I think what gegsy meant was does it stop silent, or is it humming and are any lights showing. 😉
    jontymox
    Good morning,
    Sorry… yes, my mistake/oversight.
    The m/c does humm (pump?) but no water in system other than residual.
    Only light showing is selected programme LED
    jontymox
    #317190
    clivejameson
    First check is the obvious…is the supply tap turned on, and is there a decent water pressure?
    If it sounds like the drain pump runs continuously and nothing else happens then it may be that the flood protection has tripped. This is usually due to food residues on the inlet side….take the LHS panel off and check that the hoses and chamber near the bottom are clean…
    #317191
    jontymox
    Thanks Clive,
    Yes, the water pressure is fine, and I have checked the matrix for blockages.
    The m/c works well for about 15 mins, then stops with the aforementioned humming noise.
    Back to the drawing board!
    jontymox
    #317192
    gegsy
    If you reset and start programme again will it start up ok again for a further 15mins?
    It may be a the re-circulation pump seizing when it get warm ?
    clivejameson
    It would probably help if you could identify the exact part which is humming 😉
    #317194
    gegsy
    It may not know the words Clive 😆
    jontymox
    ha ha,
    I’m fairly confident that it is the re-circulation pump that is making the noise. Will try and confirm later though difficult due to location and low noise.
    However, this does not explain the fact no water is evident after the first cycle.
    Surely the pump will try to work, but obviously not very efficiently without water!
    I’m wondering if the control module is fauly too.
    jontymox
    #317196
    clivejameson
    I’ve had a handful of float switches stick shut…worth a look especially if the chamber and transfer hose have been gunked 😉
    #317197
    That’s a strange one. If it’s dry and it’s humming, my money’s on the water supply. Maybe there’s an intermittent blockage at the tap end. Not a self-plumb fitting by any chance? Sometimes they don’t screw in the cutter far enough.
    Mike.
