Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Classixx dishwasher E-Nr SGS43C02GB/35
- This topic has 15 replies, 6 voices, and was last updated 16 years ago by
jontymox.
April 4, 2010 at 4:00 pm #53777
jontymox
ParticipantGood afternoon,
The above dishwasher begins its cycle well; i.e. lets water in, and pumps water around internally. (water pressure appears high, circulation pump working)
However, after draining the initial dirty water, the m/c then refuses to carry on through its cycle.
I don’t know where to start looking, as the main functions work for a while and then stop!
Could someone advise on a test procedure for this fault please?
Kind regards,
jontymox
April 8, 2010 at 6:03 pm #317184iadom
ModeratorRe: Bosch Classixx dishwasher E-Nr SGS43C02GB/35
BUMP. 😉
April 8, 2010 at 6:07 pm #317185jontymox
ParticipantRe: Bosch Classixx dishwasher E-Nr SGS43C02GB/35
Thanks iadom,
I’m wondering if it’s the control module, as I’ve tried a new inlet valve to no avail.
The m/c works initially, then stops and is dry!
jontymox
April 8, 2010 at 6:08 pm #317186gegsy
Does it stop silent,humming,lights showing etc
April 8, 2010 at 10:05 pm #317187jontymox
Yes, it does so!
jontymox
April 8, 2010 at 10:55 pm #317188iadom
I think what gegsy meant was does it stop silent, or is it humming and are any lights showing. 😉
April 9, 2010 at 7:13 am #317189jontymox
Good morning,
Sorry… yes, my mistake/oversight.
The m/c does humm (pump?) but no water in system other than residual.
Only light showing is selected programme LED
jontymox
April 9, 2010 at 8:00 am #317190clivejameson
First check is the obvious…is the supply tap turned on, and is there a decent water pressure?
If it sounds like the drain pump runs continuously and nothing else happens then it may be that the flood protection has tripped. This is usually due to food residues on the inlet side….take the LHS panel off and check that the hoses and chamber near the bottom are clean…
April 9, 2010 at 10:40 am #317191jontymox
Thanks Clive,
Yes, the water pressure is fine, and I have checked the matrix for blockages.
The m/c works well for about 15 mins, then stops with the aforementioned humming noise.
Back to the drawing board!
jontymox
April 9, 2010 at 5:12 pm #317192gegsy
If you reset and start programme again will it start up ok again for a further 15mins?
It may be a the re-circulation pump seizing when it get warm ?Greg
April 9, 2010 at 6:14 pm #317193clivejameson
It would probably help if you could identify the exact part which is humming 😉
April 9, 2010 at 6:28 pm #317194gegsy
It may not know the words Clive 😆
April 10, 2010 at 6:09 am #317195jontymox
ha ha,
I’m fairly confident that it is the re-circulation pump that is making the noise. Will try and confirm later though difficult due to location and low noise.
However, this does not explain the fact no water is evident after the first cycle.
Surely the pump will try to work, but obviously not very efficiently without water!
I’m wondering if the control module is fauly too.
jontymox
April 10, 2010 at 6:51 pm #317196clivejameson
I’ve had a handful of float switches stick shut…worth a look especially if the chamber and transfer hose have been gunked 😉
April 12, 2010 at 12:22 am #317197leavemetogetonwithit
That’s a strange one. If it’s dry and it’s humming, my money’s on the water supply. Maybe there’s an intermittent blockage at the tap end. Not a self-plumb fitting by any chance? Sometimes they don’t screw in the cutter far enough.
Mike. -
