Re: Bosch Classixx Drain Pump Impellor access?
AJCh13 wrote:Sorry, typo…
Model No is: SRS43A02GB/08
OK, access to the pump only clear once the OUTER door panel is removed to allow greater access. That allows you greater freedom to unlatch the bayonet fitting pump chamber thru the front service panel. Be sure to soak up all the water in the sump first otherwise you will flood the base.
Unplug from main first though. : zap:
Caution to be advised as it’s easy to cock things up due to very limited access. If unsure consult a local expert.
