Bosch Classixx E25 error. Sensor fault?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Classixx E25 error. Sensor fault?
  • #103715
    qprfcmark
    Hi. My bosch diswasher is not draining. I have an E25 error message. So far I have:
    1: Cleaned the filter.
    2: Checked for obstacles.
    3: Changed the pump.
    4: Changed the operating module.
    All of these remedies have failed as when I run the short or long cycle the sump is full of water either during or after the cycle coupled with the E25 error
    If I reset the program it does eventually drain and the program will restart. It will not restart if I do not drain the sump via a reset. I have a Bosch Classixx serial number SMS40C02GB
    Is there a sensor fault of some sort?
    Mark
    #494311
    check you have the correct pump, there are 2 different pump in this range and the connector looks similar
    the pump itself act as a sensor with the module sensing the current drawn to determine if water is in the machine. They use the wash motor for the same purpose at other points in the cycle
    kaibart
    Failing what dave has mentioned the heat exchanger in the left hand side may also cause this issue
