I have a bosch classixx dryer WTL 6102GB/02. The empty container light comes on after about 5 mins and the heating stops. I understand this is a common problem and have searched the internet for a solution. I have so far cleaned the black pipes and the small plastic valve that feeds the container. Removed the pump at the bottom of the machine and cleaned and checked that the pump is in working order. Cleaned out the reservoir that the pump and float sits in. checked the float switch works with a multimeter. Cleaned all filters, and found the small red switch at the back of the machine and pressed that but the fault still continues, Have also cleaned the sensor that is in the front of the dryer. Am pulling my hair out with this. Am just wondering if there is anything I have missed or is it time for a new machine
Kind regards
Ian
Thanks for your reply.It is a strange one we can back from hols and the missus put a load in and this error appeared. I will check the wiring this evening, and if its the PCB,will take it straight to the tip
