Bosch Classixx Fridge Freezer light problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch Classixx Fridge Freezer light problem
  • #72522
    Fred Upp
    The bulb on our 2009 model Bosch Classixx fridge freeze blew the other day. I’ve since tried fitting 2 new bulbs, but neither works despite working fine when I try them in a different fridge. The fridge itself is working fine so, before I start removing the switch and the light fitting, I was wondering whether there was maybe a separate fuse somewhere for the light or something else I can check out.
    Any suggestions would be appreciated. Thanks
    #384782
    triratna
    Re: Bosch Classixx Fridge Freezer light problem
    Hi Fred,
    I seem to have the same problem. Have you managed to fix the problem with your fridge?
