Re: Bosch Classixx KGU34640GB/06 problem
I would first of all try switching it off for 24hrs (towels in freezer) and then see how it goes. If a fault is apparent it will more than likely materialise. DON’T fill freezer until you are happy that both fridge and freezer are working correctly over say 7 days. I would recommend putting some cheap bread or something in freezer over this period, not only as a guide to freeze ability but nothing in a frost free freezer compartment isn’t good practice.
If the fault re-occurs and the doors are sealing I would seriously consider getting pro help as these are not really a DIY machine as they are quite sophisticated in respect to a standard fridge freezer.
The link below should point you in the right direction if required 😉
