Bosch classixx maxx
  • #94432
    Peter Parker
    Hello there, I have a Bosch classixx maxx, srs43a02gb/08 or sd13h1b. The water flows into the labyrinth, then through the float chamber part (sorry if that’s not what it’s called) and after a while it sounds like it’s trying to start but the water is being pumped out again. No water coming through the spinning arms, and just a bit of water collecting in the bottom of the drain hole. I have changed both the labyrinth and the chamber with the float switches on it so that everything is clean. Any suggestions? Thanks in advance.
    #457328
    Re: Bosch classixx maxx
    Is the pipe between the fill matrix and the sump totally clear? Also, is the plastic base thoroughly dry?
    #457329
    Peter Parker
    Hi Martin, I’m not sure if it’s blocked but I have just taken the drain cover off inside and it’s full of water, should it be like that? Is it possible to push a flexible wire through it? I don’t think there’s any water in the base, I can’t see anything wet down there. Thanks for the reply.
    #457330
    if by drain cover you mean the silver sump cover inside the machine then there will always be a bit of water in the bottom (up to an inch) but not a lot
